1. Проклейка резиновых уплотнителей оконных арок (она же акция 66D4). Я ее прошел, дело 30 минут на все про всё. На скорости больше 120кмч свист как от обтекания зеркал был.
Можно решить просто: отогнуть уплотнитель арок окон и в щель набить порезанный поролон от посудомоечных губок)). Британцы так сделали, чтоб официалы кривыми руками что-нибудь не сломали.
Что имеем в европе:
Reference : R/2008/027
Manufacturer Ref : 70D1
Make: AUDI
Model : TT Coupe (with child seats)
Launch Date : 31/03/2008
Numbers Involved : 286
Build Start Date : 05/01/2007
Build End Date : 20/02/2007
Concern : TRIM MAY COME LOOSE IN A COLLISON CAUSING INJURY
Description : In an accident where the rear seat belt tensioners are triggered, the side pillar trim could protrude into the passenger compartment and cause an increased risk of injury for both the front and rear passengers.
Remedial Action : Recall the vehicles that are likely to be affected to replace the front retaining clips on both side pillar trims.
Vehicle Id : TRU###8J#71000102 to TRU###8J#71026630 and TRU###8J#81000101 to TRU###8J#81001178
Model : TTS Coupe (with child seats)
Build Start Date : -
Build End Date : -
TRUZZZ8J_91000294 - 002127
Damage number: 97N7 066 002
Repair instructions
Technical background
On Audi TT vehicles manufactured within a limited period, the onboard supply control unit is not coded correctly. This leads to the daytime running lights not being dimmed when the side lights or the headlights are switched on.
Remedy
The on-board supply control units on the affected vehicles must be re-coded with the SVM.
Customer notification
Customers do not need to be informed directly of this campaign. Please ensure that all affected vehicles are checked and repaired before delivery to retail customers. You should also inform your new and used car sales departments so that the vehicles affected can be checked and, if necessary, repaired immediately (and not just before sale).
Model : TT
Build End Date : -
TRUZZZ8J%91000001 - 999999
Damage number: zzzzzzzzzzzzzzzz
Technical product information Transaction No.: 2017495/2
Leather cover of backrest chafed on side - TT / R8 Release date: 15-Apr-2008
Customer statement / workshop findings
Leather of seatback cover and side panels is scuffed
Signs of wear indicate unusually heavy mechanical stress as a result of clothing with rough surfaces, jackets and trousers with zips, buttons with sharp, broken edges or with sharp-angled shapes, Velcro fastening, brand labels or tags, belts cut with sharp edges, as well as rivets or jewellery.
This unusually heavy stress when getting in and out of the vehicle, combined with poor or no leather care, is generally the cause for this mechanical damage (which can already occur after a short period of time).
In these individual cases, an individual appearance will result through use and care by the customer.
Please refer to the information in the manual on maintaining the vehicle's value (see 'Cleaning and Care').
Production change
To optimise comfort in the entry area, the side panel on the seat back has been reduced.
The construction of the seat back frame, seat back upholstery and seat back cover has been redeveloped and implemented in the series.
As of 03.2008 vehicle no. 8J 81 042011
The improved comfort in the entry area with reduced side panel in the seat back cannot prevent this mechanical damage which is caused by rough clothing/jewellery.
Measure
It is only possible to prevent damage to leather seat/backrest covers by avoiding the type of clothing which causes this damage.
Repair or reconditioning of leather seatcovers according to the current value with the VAS 6218 is already being carried out at several dealerships and is recommended here.
Cleaning or repair of signs of wear caused by exceptionally heavy mechanical stress cannot be treated as a defect covered under warranty.
Accounting instructions
This is not a defect covered by warranty.
Model : TT
Build End Date : -
TRU___8J_71000101 - 006036
Damage number 55E6 066 002
Pre-delivery campaign 55E2 Transaction No.: 2012922/2
Sealing plugs on inside of bonnet Release date: 07-Sep-2006
Repair instructions
On Audi TT vehicles it is possible in isolated cases that, contrary to normal assembly instructions, two sealing plugs were omitted on the inside of the bonnet. This can cause odours to enter the interior of the vehicle and may lead to customer complaints.
On some vehicles with DSG gearbox the connector terminals for the earth connection on the longitudinal member were secured directly on top of each other, and not offset sideways by 90°. The cables themselves may also be turned 180°, giving insufficient contact area between the terminal and the earth point on the longitudinal member.
Remedy
On the affected vehicles, in accordance with the criteria listed, the sealing plugs must be retro-fitted on the inside of the bonnet and/or the earth cables on vehicles with direct shift gearbox must be repositioned at the earth point on the longitudinal member (left-side).
Repair instructions
Model : TT
Build End Date : -
TRU___8J_71006539 - 023475
TRU___8J_81000164 - 000736
Damage number: 55E6 066 002
Workshop campaign 55E6 Transaction No.: 2018536/1
Checking gas strut Release date: 12-Aug-2008
Repair instructions
On Audi TT Coupé vehicles manufactured within a limited period, one of the gas struts can become separated from the ball stud on the tailgate when closing the tailgate.
Remedy
The manufacturing date of the gas strut on both sides of the affected vehicles must be checked. The gas struts must be replaced if necessary.
Check
If the vehicle is not already listed as repaired in the "vehicle-specific notes" (in Service Online or ELSA), check the Service Schedule for the entry '55E6 completed'. If the entry is not listed, carry out the required work in accordance with instructions.
Model : TT
Build End Date : -
TRU___8J_71000101 - 016827
TRU___8J_81000101 - 000198
Damage number: 66C1 066 AUN
Workshop campaign 66C1 Transaction No.: 2013696/1
Checking function of tail spoiler Release date: 06-Dec-2006
Repair instructions
It is possible that malfunctions can occur in the drive mechanism of the tail spoiler on all Audi TT vehicles manufactured to date
not use any other types of lubricant; in particular do NOT use special lubricant 'G 052 172 A2' (100 ml), because this container also contains propellant gas and solvents.
Note
If the spoiler sticks, guide it out by hand.
- Lubricate all pivot points on the left and right hinges. Use special lubricant (30 ml) G 052 172 A1.
- Operate the spoiler 5 times to allow the oil to penetrate into the bearings.
Model : TT
Build End Date : -
TRU___8J_71000101 - 042408
TRU___8J_81000101 - 043569
TRU___8J_91000101 - 000529
Damage number: 66D4 066 002
On all Audi TT Coupé vehicles manufactured to date, it is possible that wind noise can occur in the area around the A-pillar on both sides of the vehicle.
Remedy
The measures for sealing the roof trim strip must be carried out on the affected vehicles.
Repair instructions
- Starting at the bottom, carefully prise roof trim strip off edge of roof using a plastic spatula.
(Foam spacers are located at points shown in illustration.)
- Measure the distance between the foam blocks.
- Shorten insulation strip - 8E0 831 575 A - to measured length.
- Compress the tailored insulation strips.
(For illustration purposes, only part of the insulation strip in the photo is compressed).
- Peel backing off adhesive strip.
- Spray all sides of compressed insulation strip (including the adhesive side) with upholstery and textile cleaning foam.
- Push insulating strip sideways into cavity between the two existing foam blocks.
- Repeat the procedure at the remaining two points and on the other side of the vehicle.
TTS Only.
TSB 2019062/1
Symptoms are misfiring between 6000-6500 RPM's under heavy load accompanied by power surging.
Technische Produktinformation
Vorgangs-Nr.: 2018868/3
Verbrennungsaussetzer bei hoher Drehzahl - 2.0 TFSI im Audi TTS und S3
Freigabedatum: 19.02.2009
P0303 - Zyl.3 Verbrennungsaussetzer erkannt (zu 80% werden auf diesen Zylinder die Aussetzer eingetragen)
